Mike Gleason
- May 23, 2005
- 1
Hello All,<br /><br />I hope everyone is doing well. This is my first post so I'll appologize in advance if I outstep my boundaries. I have a 1997 Johnson Outboard Tiller with a hydraulic tilt/trim system. The motor is stuck in the up position and I have a fishing trip planed this weekend. The tilt/trim button doesn't work but when I press it the relays just click. I replaced the relays and the tilt switch on the side of the motor but the tilt/trim will still does not work. I think I have a hydraulic pump issue. Is there a way to bypass the hydraulic pump and manually lower the motor so I can at least go on my trip? Please respond when you can with any ideas.<br /><br />Thanks,<br /><br />Mike
