  #1
Old July 20th, 2005, 09:28 AM
wisdom62 wisdom62 is offline
Default 98 Evinrude 115hp 2 stroke, Hard to start,
I'm new to boats, Just got a 98 Evinrude 115hp 2stroke. In neutral I make sure bulb in firm, then choke start it. Usually starts up and idles kind of roughly, figured cause its 2stroke. But then it dies and is hard to turn over.My biggest question, after trying to crank it over a couple times, it stops cranking, i turn the key and it tries to crank a little then stops. I have to let it sit for a sec before trying to start it again, Is this normal or is there something wrong the the battery turning the starter, or the solenoid. Sorry if my question to to vague, Newby here still figuring things out. thanks for the help
  #2
Old July 20th, 2005, 09:38 AM
bhile's Avatar
bhile bhile is offline
Default Re: 98 Evinrude 115hp 2 stroke, Hard to start,
Check all your electrical connections and be sure they are clean and tight. How old is the battery? If you don't know, it wouldn't hurt to have it load tested. Your local auto parts store should be able to do that for you.
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #3
Old July 8th, 2008, 01:02 AM
michael96048 michael96048 is offline
I just got the same motor and I had the same problem. Mine was sitting for 3 years with the same fuel and oil in the carbs so I naturaly drainded everything I could. I figured I would give it a go and try to start it. Didn't work.... When it turned over it would start for about 3 sec and die. I just took the 4 carbs off and cleaned them with about 3 cans of carb cleaner, put it back togeather, and it fired right up! So I sugest new fuel and oil along with a good cleaning. That 2 stroke oil mixed with the 3 year old fuel realy made a mess of things........GOOD LUCK!
Michael
  #4
Old July 8th, 2008, 03:55 AM
SKEETR SKEETR is offline
I am in the process of fixing a similar problem. It still could be your solenoid but in my case it was a bad ignition switch. Corroded contacts not allowing starter to stay engaged and also preventing choke from operating properly.
  #5
Old July 8th, 2008, 08:26 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
9.9hp 4 Stroke ('99) very Hard to start ! John from Madison CT Yamaha & Suzuki Outboards 3 October 29th, 2008 02:15 AM
1977 115hp Evinrude hard start after running SyLord Johnson & Evinrude Outboards 5 August 25th, 2006 11:10 AM
1983 115hp evinrude no WOT, hard start, when cold fsds123 Johnson & Evinrude Outboards 1 September 4th, 2003 11:27 AM
'73 Johnson 115hp hard to start. flykr2s Johnson & Evinrude Outboards 9 May 23rd, 2003 05:23 PM
77 Evinrude 115HP hard start & irratic speed 76pig Johnson & Evinrude Outboards 5 August 13th, 2002 03:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
