I need some input on this engine. I rebuilt this engine for my own use fishing our local river. The power head is a total rebuild. Pistons, rings, gaskets, seals. The problem is the engine is hard to start when cold, once started, the engine runs fine, and will start with little effort for the rest of the day. I have two spare carb's that have been rebuilt, along with the carb on the engine. Changing them makes no difference. The magneto has been redone with all new components, and put's out the proper spark. This engine has the 22 cubic inch block with the 1-3/8" bore carb. The sync, and link is right where it belongs, along with ignition timing. I have worked with choke spring tension, and did'nt make any difference. I have worked with a lot of these engines, but this one has me on the ropes. I have two older 18 HP engines that have the same 22 in. block with 1" bore carb that start, and run as they should.
