how do you get to the water pump in my motor?
M macaswell33 Recruit Joined May 20, 2005 Messages 1 May 21, 2005 #1 how do you get to the water pump in my motor?
M mikeyzx2 Chief Petty Officer Joined May 1, 2005 Messages 633 May 21, 2005 #2 Re: 1977 115 evinrude water pump repair You have to remove the lower gear housing (the foot) it's mounted to the lower unit though the driveshaft
R REELSPORT Petty Officer 1st Class Joined Apr 14, 2005 Messages 235 May 21, 2005 #3 Re: 1977 115 evinrude water pump repair sounds like you need a manual before you tackle this job. It can be tricky without one. good luck
