110 evinrude won't turn off, help
g-reg
i replaced my ignition switch due to the motor not stopping when the switch is turned to the off position. the only way to stop it was to hit the kill switch. after replacing the switch the motor runs but will not stop again. however the kill switch isn't functioning properly either. now the only way to kill it is to choke it to death, no pun intended, ha ha. what possibly could be the problem. both switches are 3 position w/ push choke. i believe it is hooked up the same as it was origionally.
rodbolt
Re: 110 evinrude won't turn off, help
could we get a year model of the motor and a description of the ign switch type used? control box mounted, panel mounted? and the lanels on the back side of the switch. does the swich back side have 3 terminal or 5 ?
