Re: 1993 Evinrude 225hp temp gauge reading wrong
The problem is with the guage, That engine with a non pressurized cooling system, can't hit 240 degree's. 140 degree's should be about right with the engine at idle, not at cold, before start-up with the key on. I should not have said it can't hit 240 degree's, it certainly can without cooling water. At that point, it should come to a squeaking stop.
