I have a 1996 150 Evinrude /Carberated. There was another post with what seemed to be the same problem but no follow-up with what fixed the problem. I can start the motor and it will run only if the key is held to the start position. As soon as I return it to the run/monitary position the motor shuts down. I have replaced the switch and the power pack. I have checked all the ground leads, plugs for burns or shorted wires and can not find anything wrong. I thought about the coil packs but the engine will run as long as I keep the starter running. jmarler posted his in january but I did not see if or what he did to fix the problem. I am new to the posts here but have seen a lot of sound advise to solve other problems and would be very greatful for any help.
