150hp 1999 johnson bucks shakes and dies
Blue Note
My 1999 150hp ocean pro intermittantly will cut out and not restart. While then cranking, trying to restart, the motor will catch and then buck like it wants to come off the transom and stall. 24 hrs later, turn the key and it runs smooth at all RPM's for up to an hour and the same thing starts over. I recently decarbonized. recirculation valves? Seems to have plenty of fuel. compression looks good on all cylinders which i think leaves ignition. Does any body have any thoughts?
Blue Note
Re: 150hp 1999 johnson bucks shakes and dies
Could the optical sensor be dirty or defective?
Blue Note
Has anyone any experience with this optical sensor?
phatmanmike
my 1991 225 did same/ similar thing.<br /><br />turns out that it WAS ignition related. the plug wires were so rotten, they were just shorting out.<br /><br />just my 2 cents
