  #1
Old July 15th, 2005, 06:45 PM
rost495 rost495 is offline
Default 200 Evinrude-- hole in block?
Got my engine further apart. We ended up taking this thing apart in a weird order. Suffice it to say we go to(sorry I don't know the boat motor terms probably) taking the carbs off as a unit. Then the plate(intake?? has the reeds in it) off behind the carbs. Which reveals a hole in the (would be oil pan in a regular motor) lower powerhead block???Ok so is the whole thing now toast? Can I get that piece only from salvage and keep going. I suspect its a mated part so I'd have to have both parts of the block(or is it 3?) before I can or could get going again.Right now I'm suspecting its better to try to find a used motor but I'm always open to more thoughts.I should add that we don't have the flywheel off yet. Thats next on the list(told ya we are probably doing it backwards). We'll then pull the bearing cap and pull the part with the hole in it off(amazingly enough we have the part that broke out. but I suspect welding would be really stupid idea)Plus I want to get further into it just to see how bad the inside is after blowing a hole out and what could have possibly caused it for grins.I now suspect that the guy that sold it, realized it had a hole. And when he meant it ran rough with smoke, that meant it had a hole and was ruined....Thanks for all input!Jeff
  #2
Old July 16th, 2005, 02:27 AM
Blueclaw Blueclaw is offline
Default Re: 200 Evinrude-- hole in block?
depending on where the hole is in relation to the crank shaft journals would determine if it could be welded. Pull the flywheel and split the crankcase. Take the broken piece and the intake side of the crankcase to a machine shop or welder and see what they think.Look at your crank and con rod where this piece is missing from to determine what the cause of this hole was. Con rod cap bolt loose? have to find the source of the problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hole in Engine Block???? mattsmall1972 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 June 4th, 2006 02:05 PM
Welding hole in block? rost495 Johnson & Evinrude Outboards 6 July 17th, 2005 06:55 AM
'Hole' under windshield...how to block? chris in va Boat Topics and Questions (not engine topics) 3 June 1st, 2003 05:38 AM
Cracked or should i say hole in block customcar2boat Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 12 May 25th, 2003 05:54 PM
Hole in Mariner block ??? Valv Mercury & Mariner Outboards 4 August 9th, 2001 11:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
