abbocoeeboat
- May 8, 2005
- 3
Thanks to cvx35, CATransplant and Paul Moir, the old lady cranked over, coughed under choke and started on the third crank (once I figured out the starter issue) last night. Wish my 89 Erude 60HP would've started that easily (what a pain - glad I sold it) With "ear muffs" on the water intake I noted no return flow through the top exhaust....and shut it down immediately.<br /><br />I thought at first the starter was shot, or I had a short in the switch - finally figured the motor was not really in nuetral and that the battery was weak - jumped it off and the starter immediately jumped up and worked like a charm.<br />It was fun to watch it work. Cleaned the carb bowl and lubricated cylinders as suggested before any crank over.<br /><br />Should I take it to the lake and get it good and immersed (leave it on the trailer)before I assume that my water pump or impeller are frozen up? I know these old motors have a strange (and small) intake. Are the impeller and pump an easy change...or should I go get in line at my repairman's place? <br /><br />Excited that she'd turn over! Thanks for your help. Once I can get it running, I have lots of paint and fix up to do.
