1970 Evinrude 60 HP Lower unit fluid
venkman03
I need to change the lower unit fluid in a 1970 60 HP Evinrude outboard with electronic transmission. We do not have our owner's manual, but we know where the draining valve is. We thought there might be another valve higher on the motor, but we couldn't find one. What do I have to do to add the new fluid? Thank you.
R.Johnson
Re: 1970 Evinrude 60 HP Lower unit fluid
The upper vent screw is just above the cavitation plate on the same side of the gearcase.
