I am trying to start a used, previously "running" 1969 55hp hydro-electric E/J motor. After most of the connections have been made, the engine will turn over well, but no spark at the plugs. I have NOT connected the throttle/control box.....yet. Also, the motor is stuck in forward. The CLYMER manual says that this is because of bad diodes. Fine. But my friend, who's motor is exactly the same, starts fine from being in forward gear. So, is there a safety issue I must resolve, or is the "CDI BOX" bad? Many years as an automotive mechanic. Little marine/2-stroke knowledge to date. <br />Also, there is a 1.5" square black box on the right side (port?)(from the rear) that when depressed, a voltage is signaled, but to what? "Button" moves maybe 1/32" to activate. Thanks to all who help a novice marainer!!
