JasonJ
- Aug 20, 2001
- 4,163
First off, it is a 1965 33 hp Evinrude, Model #EO1342, Ser # 33552B. <br /><br />Anyway, it is on a buddies' boat, and it ran horrible last year then quit, and he was going to sell the whole mess cheap just to get rid of it. I did not have the time back then to look at it, but he still had it this year so I told him I would look at it for him. As it turned out, it was a blown head gasket and a weak water pump. I will replace the head gasket, and the water pump, but my question is, will I have to pull the power head off to disconect the shift linkage like on the older johnyrudes? I guess I will find out anyway when I tear into it, but a heads up will make things go a bit more quickly. <br /><br />The carb and ignition are in top form, thankfully.<br /><br />I have already popped the head off. The bottom cylinder was completely blown, and the top cylinder was partly blown. I was lead to this by the fact that after I got it running again this time, and checked the plugs, that the bottom plug was clean and had water on it.
