Just tried to get this motor going for spring fishing and I now have a sore arm from pulling on it. Ran it dry before putting it up last year and it is stored inside. Primer bulb pumps up nice and firm, new plugs with good fire gapped to 030. I have checked all the fuel line connections and they are good, I have gas to the carburetor. Was able to get it running once for about 15 secs by spraying a little gas in the cylnders and then it quit. I assume that it is not getting gas properly. Just did a serach on this forum and found the article by "dolluper" on these motors . I have removed the carb and I am on my way to get a carb kit. The only thing I have noticed is that the black plastic part on top of the carb that holds the idle screw is cracked slightly where the air silencer screws on, could this be the problem ? Any thoughts or suggestions would be appreciated <br />Thanks<br /> cer79
