After running it on muff's for about 15-20 minutes, the overheat alarm went off for about 3 seconds, then it stopped. I ran back to the throttle box and turned the engine off, after it sat for about 20 seconds, the alarm went off again. There was plenty of water pressure, and the pee hole was peeing like crazy, but the water comming out of it was no where near warm. I touched the head, and it was quite warm, but it didnt burn my finger but it would hurt if I held it there for longer then a second. I replaced the thermostat, and pressure release valve, head gasket, water pump, and cleaned all the water passages with a wire brush. Is this anything I should be concerned with? What would you reccomend?
