I hooked the water hose to this Engine and it leak water right where the Powerhead bolts down.I'm just wondering if this to big of a job to do at home? Please advise?
Hi,Everything is a big job when you do it the first time. But it will save you money and you will learn something new. I don't think that the leak is nothing to worry about. There where another similar post somewhere here on iBoats. If you are going to fix the leak you will have to lift the powerhead off and change the gasket. Buy a manual and it will be easier. A digital camera is nice to have when taking engine apart. Measure the compression in the engine before you take it apart. Take the cylinder heads also off and check the condition of the cylinders. Do all the neccessary service at the same time when you have the powerhead off. Take your time! Robbi
