  #1
Old July 8th, 2005, 01:48 PM
michaeljcarr michaeljcarr is offline
Default Evinrude 115 will not crank when restarting
I have 1992 Evinrude 115 OB that has started giving me grief when restarting after being run for 10-15 minutes. The engine starts great when cold. When I turn the key after the engine has sit for 15+ minutes there is no click and the starter will not engage. If I press in on the key I can hear the choke operating. The shifter is in neutral detent. I can start the engine with the pull rope by leaving the ignition in the on position with no problem. I have had the boat in for service a number of times but the service people never seem to be able to get the same problem to occur. Any comments. Where do I begin?
  #2
Old July 8th, 2005, 05:55 PM
Solittle Solittle is offline
Default Re: Evinrude 115 will not crank when restarting
First a BIG WELCOME!!You might begin by taking off, cleaning and reattaching every electrical connection to the starter, starter solinoid and battery (not just tighten but remove & lightly sandpaper the connections). Next make sure that your battery is fully charged. After that I would look at the neutral safety switch. Sometimes they can stick and you can free them up by jiggleing the throttle/gearshift lever.You can also bypass the solinoid with a screwdriver. That should get you started - engine too I hope.
  #3
Old July 9th, 2005, 07:09 AM
Quote:
Originally posted by SoLittle: First a BIG WELCOME!!You might begin by taking off, cleaning and reattaching every electrical connection to the starter, starter solinoid and battery (not just tighten but remove & lightly sandpaper the connections). Next make sure that your battery is fully charged. After that I would look at the neutral safety switch. Sometimes they can stick and you can free them up by jiggleing the throttle/gearshift lever.You can also bypass the solinoid with a screwdriver. That should get you started - engine too I hope.
  #4
Old July 9th, 2005, 07:12 AM
How do you bypass the starter solenoid with screwdriver?Previous posts have indicated neutral switch replacement or adjustment or starter solenoid replacement as solution. Which one should I start with?
  #5
Old July 13th, 2005, 08:00 PM
  #6
Old July 13th, 2005, 08:41 PM
McGR McGR is offline
Though you probably could do it, I wouldn't use a screwdriver to test the solenoid, you could easily create a hell of a short between B+ and ground if you touch the wrong things together, seems awkward too. Rather, just make a short jumper wire out of 12-18AWG hook up wire. Next time the motor won't start ,take the short jumper and jump between the small terminal on the solenoid (the one of the two NOT connected directly to ground) and the Battery + large solenoid terminal (the one coming from the battery NOT the one going to the starter). If your motor cranks when testing with this method, then you have a problem with the key/starting circuit. If the solenoid doesn't activate/motor doesn't crank you either:1. Have a bad solenoid.or2. Have a poor positive or ground connection to the solenoid.
  #7
Old July 14th, 2005, 03:12 AM
Thanks for the info. I'll give this a try. Would you attach clips to the ends of the wire or just use bare wire?
  #8
Old July 14th, 2005, 05:47 AM
Silvertip Silvertip is online now
ITs a momentary connection so either will work. If you want to get fancy, buy a cheap push button switch, attach two wires to it, add clips to the other end of the wire and you now have a handy test tool or emergency start device to keep on your boat. Attach the tester, push the button and away you go (assuming of course the solenoid is ok).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'89 Evinrude Won't Crank Crash0016 Johnson & Evinrude Outboards 9 May 19th, 2006 04:05 AM
Evinrude 115 Restarting Problem When Hot PCboater Johnson & Evinrude Outboards 7 August 14th, 2005 09:22 PM
evinrude 40 HP crank from '74 '75 or 76 eenhorn Johnson & Evinrude Outboards 7 May 4th, 2005 11:48 PM
88' Evinrude 70, restarting problems scott324 Johnson & Evinrude Outboards 7 August 14th, 2004 09:12 PM
restarting '85 Evinrude 90 hp v-4 sat up 5 yrs Jamar Johnson & Evinrude Outboards 9 September 6th, 2002 09:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
