  #1
Old July 5th, 2005, 06:01 PM
monoshock monoshock is offline
Default 18' Pontoon 40HP Evinrude replacement prop questions.
Hello, I’m looking for some help on a replacement propeller for my pontoon 18 ft tracker Bass Buggy with a 40HP Evinrude. The aluminum one on it now is fine, it’s a 12 ½ x 13. I want to have an extra so thought I might as well get a SS one and have the old one for the extra. I found a close out deal on iBaots for a Michigan Wheel Rapture 11 ¾ x 15. Would this be a good replacement? I’m thinking a smaller diameter with a steeper pitch it should be okay, but want some input from someone with more experience. ThanksHere's the link for the new prop. http://www.boat-props.com/propellers...-14/index.html
  #2
Old July 6th, 2005, 05:14 AM
Default Re: 18' Pontoon 40HP Evinrude replacement prop questions.
Help
  #3
Old July 6th, 2005, 05:25 AM
Silvertip Silvertip is offline
The small change in diameter has little effect on the performance of the prop. Pitch changes have the most effect. The 15 pitch will very likely cause lugging of the engine. The 13 pitch is probably at the limit for your 'toon. 15 pitch on a 40 is the "standard" prop for a "V" hull and in some cases even that is marginal. I'd stick with a 13 and your engine will live longer.
  #4
Old July 6th, 2005, 05:34 AM
Thanks,Upinsmoke.
  #5
Old July 6th, 2005, 05:49 AM
Upinsmoke, Do you think this prop would work?Here's the link. http://www.boat-props.com/propellers...-14/index.html
  #6
Old July 6th, 2005, 08:03 AM
It should work just fine. If its a ventilated prop as the info indicates, it will help with getting started. Vent holes allow the engine to rev a bit during takeoff. The holes are not a factor at higher speeds. They can be plugged if it turns out they create a problem. I may pop for one of these myself. Thanks for the link.
  #7
Old July 6th, 2005, 08:31 AM
Thanks for your help. I just ordered one,about $82 with shipping, I,ll let you know how it works out.
  #8
Old July 11th, 2005, 07:47 AM
Hello, I received the new Rapture - 11-3/4 x 13 - 3 blades SS prop on Friday and took it for the first run on Sunday. I was very disappointed; As soon as I throttled up I could tell this wasn’t going as planed. The new prop dropped my top speed about 5mph, and it took longer to get to top speed. I reinstalled the old prop. Does anyone have a suggestion, the new prop is the same pitch, just ¾ smaller?
  #9
Old July 11th, 2005, 08:14 AM
bump
  #10
Old July 11th, 2005, 09:20 AM
walleyehed's Avatar
walleyehed walleyehed is offline
The SS prop is a much more efficient design for starters.The speed drop is not good but most importantly, what is the RPM at with new?? with old??
  #11
Old July 11th, 2005, 10:12 AM
I don't have a tach. It's for sure reving higher, I could tell by ear.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
18' Pontoon Prop Replacement Question monoshock Non-Repair Outboard Discussions 1 July 6th, 2005 05:15 AM
1989 40hp evinrude questions Bill Collector Johnson & Evinrude Outboards 9 May 2nd, 2005 05:49 PM
1989 40hp Evinrude questions Saboat Johnson & Evinrude Outboards 7 February 26th, 2005 06:52 PM
Pontoon Top replacement Stratguy Boat Topics and Questions (not engine topics) 2 January 17th, 2004 11:20 AM
Evinrude 40hp weight and Jap replacement alternative? Mike Sherwood Johnson & Evinrude Outboards 4 January 4th, 2003 10:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
