Evinrude 20 HP stalls after while use
Hi, my mom has 2 stroke ´92 Evinrude and it stalls after 10 - 15 minutes use. It sounds like lack of fuel suddenly. But even used primer bulb, it wount start. It wount start untill cooled down, but stalls quite soon when pushed to full throttle. Then it worked well again and ran 10 min with full throttle and water in the peeing whole is not too hot, so it doesn't look like overheating problem. Checked already tank and hose, they are clean. Also took the carb apart, inspected and it looked clean. Any ideas?
