I stripped, cleaned and re-built the 4 carbs on my '86 120 over the winter. Fired it up on the hose today and the idle seems a lot lower than before. I used to get around 1500RPM on the hose now its like 600 RPM and stalls easily. Haven't put in in the water yet. I havn't done a link and sync yet as I didn't touch any linkage I figured I wouldn't need to (I guess my first mistake!)<br /><br />My real question is do I have to check the WOT timing as well or can I just assume its OK? If I have to check it I have read that if you un-hook the carb linkage so the butterflys don't open you can check the timing on the hose as the motor will only reach about 2500 RPM. Any comments on this procedure ?
