  #1
Old July 1st, 2005, 05:48 PM
Jarred Jarred is offline
Default Old 2 stroke 55 evinrude no serial # to go off of Please Help
I recently purchased a boat and motor, i need to id the motor to get some parts. The motor has three carbs and and most of the part numbers start with 318..., there is a frost plug on the top it says (co573152). All i know for sure is it is a 55 evinrude. Any help would be greatly appreciated.
  #2
Old July 1st, 2005, 08:07 PM
mikeyzx2 mikeyzx2 is offline
Default Re: Old 2 stroke 55 evinrude no serial # to go off of Please Help
There is not a metal tag on the transom with the model and serial number on it? is the motor an older looking or newer looking model? also are you positive it's a 55HP? in the book all the 55's from 73-90 were two cylinders, I don't know if they became 3-cylinders starting in the 90's
  #3
Old July 1st, 2005, 08:17 PM
R.Johnson R.Johnson is offline
I would guess your engine to be a 1969, with a push-button shift, and a single throttle cable to the engine.
  #4
Old July 1st, 2005, 08:25 PM
I am posative its a 55, and it has three carbs. The throttle control has a push button to go from forward, nuetral, reverse. When i was searching on the net I found out that it could be either a 68-69, or then it jumps to 76-79. Does the push button shift meen its a 60's?
  #5
Old July 1st, 2005, 08:54 PM
I forgot they had the 3 cyl. in 68. The 3cyl. was 55 HP in 68, and 69. It jumped to 60 HP in 1970, so your engine was one of those two years. The push-button, or hydro-electric shift was gone after 1972. The Johnson engine did not use push-button, they used a single lever control with the shift switch inside the control box. Your engine is the same, for all practical purposes, those two years.
  #6
Old July 1st, 2005, 09:00 PM
Thanks for your help, I appreciate itregards Jarred
  #7
Old July 1st, 2005, 09:44 PM
Another question, how would i go about pin-pointing it down to the exact model? according to what ive read they made two models in 68 and two in 69,I would like to pick up the manuals for that specific model if I can. Any help would be appreciated. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
25hp 2-stroke serial number laurencegreen Mercury & Mariner Outboards 2 July 9th, 2006 01:31 PM
1989 9.9 four stroke Yamaha serial # joblo33 Yamaha & Suzuki Outboards 3 July 13th, 2005 10:52 PM
Suzuki DT40 serial #004003 506433 & serial #04003 504848 any information app scislander Non-Repair Outboard Discussions 1 June 22nd, 2004 10:35 PM
Evinrude E-Tec E50DPL 2-stroke vs. Johnson HP50 4-stroke Petrol Non-Repair Outboard Discussions 11 February 18th, 2004 11:22 AM
Honda 9.9 4-stroke serial ID chiefs12 Honda & Tohatsu/Nissan Outboards 1 March 17th, 2003 02:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
