plusorfive
- Apr 28, 2005
- 3
When the motor is cold, I have a hard time getting it started. Here's what happens. I prime the bulb till it's firm. Then I hold down a black button which I think is either the choke or a primer??? As I am holding down that button I push the start button (No Key). The motor doesn't turn over no matter how long you try and nothing happens when I release the "black button". I next lift the top off the motor and turn a little red valve which I believe is on the carburator. It hisses then I hear a click. I then press the start button only and it will pop right off. When the motor is wam I have no issues. HELP. I hate taking off the cover every time. Here are the numbers fcor the motor: (1991 Evinrude 60 HP, Model: E60TTLEIB, SN# G03007849
