geekomatic
- Feb 12, 2005
- 136
I was putting the lower unit back together and getting ready to reattach the thing.As I said in an earlier post,the gears,bearings, etc. all looked suprisingly good despite the fact that the thing had NO lube in it.Looks like it was drained in the past.<br />I got everything back together and gave the drive shaft a twist.No movement at all.It seemed like it was locked up tight.Took the thing apart all over again and looked around and could not find a thing wrong.Everything spins fine without the bottom part of the lower unit attached.Re-attached everything again,making sure the shift lever was in nuetral and tightened down the screws.No Movement! Took the thing apart once again and found something that has scared the crap out of me.Please take a peek Lower unit from back . lower unit from front.According to the Seloc bible, there's supposed to be a pin on each outer part of the bearing that lines up with a hole on the bearing itself.Front bearing has one.No problem.Back bearing has what appears to be a "nub" and nothing else.Has this freakin' pin broken off??<br />I looked a little closer at the back bearing itself and found two little "dents" that just happen to match up with the leftovers of the pin back bearing.Am I nuts? Has this thing actually broken off.I can run my finger along the inside of the bearing and feel how the pin just barely sticks up.I'm pretty sure it's time to shop for a new lower unit.A machine shop would cost just as must to drill this thing out and reinstall a new pin.<br />Somebody please tell me I'm wrong and I don't know what I'm talking about.As you can all see lower unit, this thing looks in too good of shape to just give up.
