  #1
Old May 17th, 2005, 08:39 AM
SQUAWK_VFR SQUAWK_VFR is offline
Default Cutting the fiberglass on my new boat
Hello,I just received a new 05 Chaparral and want to upgrade the stereo myself--the dealer would take way too long now that the weather is nice--.I have bought the speakers and wanted to know if there was a trick to cutting thru the fiberglass to mount them. I would not want to ruin my new boat. Thanks for your help.
  #2
Old May 17th, 2005, 08:58 AM
vipzach vipzach is offline
Default Re: Cutting the fiberglass on my new boat
When I cut mine, I drilled a small hole for the blade and cut them out. Suggestions:1) Draw you circles with templates that came with your speakers.2) After you draw them use masking or dust tape and go arond the outside edges of the circle so that you do not scratch up you new boat with the saw.3) Drill the pilot hole and work up to the size that you need to get the blade in there. 4) Use a smaller fine tooth blade and take your time so that it does not chip the fiberglass.Again take your time. GOOD LUCK!
  #3
Old May 17th, 2005, 10:07 AM
mattttt25 mattttt25 is offline
if you're drilling circles, go with a rotozip. using a small blade is just too difficult, as the saw will not want to turn. rotozip will ensure a perfect circle. mark circle, drill pilot hole at center, double check saw setting, place tape over cut area, and saw away.
__________________
2002 Wellcraft 290 Coastal
Twin 2002 Yamaha F225s
  #4
Old May 17th, 2005, 10:11 AM
dorelse's Avatar
dorelse dorelse is offline
And doesn't the Rotozip have a Circle Cut attachment, for a perfect hole? Just a thought.
__________________
My Boat:
1978 Glastron Carlson CVZ-18
Project Thread - http://forums.iboats.com/showthread.php?t=357939
1986 Bayliner Capri 1600 - SOLD
Project Thread - http://forums.iboats.com/showthread.php?t=338265
  #5
Old May 17th, 2005, 01:26 PM
crab bait crab bait is offline
all good suggestions.. VIP,, has the right way,, if'n no buy 'roto-zip'.. one suggestion.. i'd cover the ENTIRE area wider then the cut with overlapping wide masking tape.. then draw outline & holes..right o the tape..this way,, you're protecting from chippin' but also protecting form scatchin' from the jig-saw foot pad..
  #6
Old May 17th, 2005, 01:34 PM
Good idea crab bait, I break those stupid roto-zip blades, that is why I just use a good jig saw blade and stick with what I can do.
  #7
Old May 17th, 2005, 02:10 PM
Realgun Realgun is offline
I have a rotozip wish I had never wasted the money on it. I bought it for the floor removal but it really was a waste of time.
  #8
Old May 17th, 2005, 03:17 PM
Moody Blue Moody Blue is offline
One caution to be aware of. Check behind where you intend to cut for any wires, cables etc that may be lurking out of sight. Also be sure the length of the jigsaw blade won't impact any structure behind the panel you are cutting. Fiberglass cuts very well using a fine-medium toothed blade. Use a dust mask and eye protection for your own safety.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Cutting a hole in my boat??? crackerjack Boat Topics and Questions (not engine topics) 14 November 10th, 2005 04:41 PM
Cutting/sanding fiberglass breton26 Boat Restoration and Building 3 April 13th, 2005 03:15 PM
Beginner fiberglass question: how to fiberglass a cutting board rino Boat Restoration and Building 13 May 27th, 2004 10:19 AM
cutting holes in fiberglass twinvee17 Boat Topics and Questions (not engine topics) 8 November 7th, 2003 09:31 AM
Cutting/drlling holes in Fiberglass longjess Boat Topics and Questions (not engine topics) 11 August 9th, 2002 07:35 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
