Moderator-Please move this post if necessary, Thanks<br /><br />I have a 1990 Sunbird Barletta 204 cc w/120 Johnson ob. The throttle/gearshift lever is all thats exposed and the "guts" are mounted behind an upholstered panel. I removed the 2 screws that hold the handle outside cover and did not see a way to remove to get the linkage behind out. I need to grease the moving parts as I'm quite sure it has never been done before. Could someone tell me how to get this thing apart to access things? Thanks
