I recently bought a Johnson tn28-5hp. The motor runs fine but there is no cooling water being discharged as far as I can tell. First question, where is the water supposed come from? Second, is there a thermostat to regulate the temp? I took the water pump out the impeller looked fine all of the tubing was clear. I think I found where the water is supposed to discharge. There is a 90 degree elbow with a hole drilled in it, the hole is clear. When the motor is running hot air, I suspect exhaust, is coming from this elbow. That does not seem right to me. Any ideas? Thanks.
