Re: 40 HP Johnson starter spring
Welcome to Iboats!<br /><br />Not really. There was a special jig available to wind them up. But I just fold them into pull start housing, catch the loop in the end with the pin on the rope pulley, and reinstall the pulley. Then wind it up 3 full turns and then as much necessary to drop a pin in through the little hole in the pulley to the housing to keep it wound. Finally I install the pull start rope.<br />Easier said than done though!<br />Good luck!
