I've got this 1969 55hp evinrude that I had running a couple weeks ago. I've posted a few threads about it but no luck. I've tore down the carb's and cleaned them out,replaced fuel lines, new fuel and all and it still won't fire up. IT will start up but only stay running as long as the key is in the start position and the starter is turning. As soon as I let go the engine stops.<br />One guy suggested iginition switch but it's brand new. Could it be the fuel pump maybe? IT's getting pleanty of spark and fuel to the spark plugs, but still nothing. Could it be a bad ground, I did lose power to my purple wire running to the switch box. I added power to the green wire and it switchs into neutral fine. Any thoughts?
