Boatingdobbins
- Jul 13, 2001
- 27
When the engine is warming up, the temperature rises into the 180 degree range and then frops to normal (140). In the past it has just gone to the 140 degree point without rising first.<br /><br />I assume the problem is either thermostats or the pressure relief valve (don't know if I have this right). I understand how thermostates work, how does the pressure relief valve work? I have replaced the thermostates in the past, but not the pressure relief valve.<br /><br />The motor has 10 psi of water pressure at idle and a good water pump.
