mix ratio
johnsonman
Hi everyone I would like to know what the oil mix ratio for a 60 johnson seahorse is and also what the 60 johnsons were made.thanx
JB
Re: mix ratio
Depends on the year, Johnsonman.<br /><br />What is the model number?
johnsonman
Re: mix ratio
I think it might be an 84 because when I bought it the guy said that it was all original from 1984 but that really dosnt mean anything.Ill have to get back to you on that one.Thanx
JB
Re: mix ratio
There should be a plate riveted to the transom clamp, Johnsonman. Failing that look for it stamped into a quarter size plug on the top of the block.<br /><br />If it is an 84, it will be 2 or 3 cylinders (don't remember if there was a 60 triple in '84) and the model number should read something like J60EL84, or close to that.<br /><br />Good luck. :)
