bigbassbrent
- Apr 10, 2005
- 18
Hi ALL<br /><br />I have 15 hp johnson that starts, runs great/fine at low speed, but as soon as I try to go fast the engine revs up and immediately revs back down again, and unless I turn the gas lever back to slow speed, the engine will turn off. I checked to make sure I don't have a tank, gas line, connector problem but that isn't the case (same issue no matter whose tank I use). I checked to make sure the fuel filter wasn't plugged up, but it is clean. I checked for fuel leaks but can't see/smell any. <br /><br />Is this a carb problem??? I don't know much about carbs but maybe some else does???? Can you help??? It is a 1980's Johnson. THanks in advance!!! Brent
