Re: 1966 Evinrude 80 hp coil
Power +12V goes into the coil tru its external or internal reisitor , 12v when ingnition is on .<br />The black ? wire comming from the ditributor goes to the - pol on the coil .<br />Clean the points , adjust to .020" or 0.5 mm .<br /><br />If you want a tack , connect the tack wire together with the black wire ( - pol ) .
