OK, this post is regarding my new 1990 johnson 120VRO J120TLESB. I have removed the junk lower unit and ordered one off Ebay. I have cleaned the battery, starter, and solenoid connections, drained and refilled the fuel tank (with premix in case the VRO isn't working), let the cylinders soak for 24hrs. with oil, and lubricated the shift/throttle cables. I took the carb cover off and the carbs appeared brand new but I sprayed a little cleaner in them anyway. The fuel primer bulb getts hard, the floats seem to be working and no fuel leaks. <br />Now, I went to see if it would start so I'd get an idea if I was wasting my time or not. I have no intentions other than to see if it would fire then IMMEDIATLY shut it down. Well it starts right up and revs WAY up.I have not let it runn more than 1-2 seconds. What do I check next other than the throttle lever position to see why so much power? Is this because there is no lower unit or is something else up. I am waiting on the manual but am suffering spring fever. Thanks for any help and sorry for the long post.
