Re: Johnson V-4 Lower Unit swap
Yes, the later ones were longer slightly. Yours should have a barrel deal that screws on the top of your shift shaft. If the other one has a solid curved end it will not work. <br /><br />However, if the replacement unit has a screw on end on the shift shaft it might be from a 1977 and still be too long (end to end). IE -- if the shift shaft on the replacement is soild, its wrong. If it had the barrel, it MIGHT be right.
