Hello there!<br /><br />I'm rebuilding the carbs in my Johnson 60 hp -89 and would like to know the correct float level.<br /><br />I believe that the float should be in the same horisontal level when holding the carb upside down. Are there any correct value?<br /><br />What about float drop? How is it measured? Is it the distance between carb and float lower or upper edge? By the way, why must the float drop be adjusted? Isn't it only the other level that is important.<br /><br />Best regards,<br />Robbi
