My '70 85hp 'Rude just got the complete water pump/housing replacement treatment.She's pumping fine.My problem is when I idle down(1000 rpm or less) my overheat buzzer/light goes off after 2 minutes or so.It did this before the pump and housing replacement also.Upper rpm water flow is excellent from my tell-tale.(I used a hose barb and hose from a tapped hole in the upper starboard cylinder head.I think this was for a factory pressure guage.)Could my tell tale be taking too much water away at lower rpm's causing the tempature to rise? Should I re-plug this and just rely on the alarm? I went out this morning and opened up the thermostat/vernatherm housing and using Rodbolts advice,I ground a small groove in the vernatherm poppett valve.This will make thermostat open a little earlier and bleed air out of the housing right?I'm wondering if it's water deflectors in the head covers.Any advice or suggestions? Thanks,C.C.
