1987 40 horsepower gearcase assembly
I have a lower unit that someone else disassembled. Does anyone know the proper procedure to reassemble.<br /><br />Iam having a problem with assembling the pinion gear in the proper sequence with other gears.<br /><br />It will now go down vertically on the drive shaft because it is too large.<br /><br />I can assem inside case, but the gears will not fit into case after.
