Re: 1986 Evinrude 60 hp oil injection
If you want to reactivate the VRO, you first need to make sure everything is still there, that the wiring has not been cut, and that the VRO pump and oil tank are there. You really need a service manual specific to your engine to identify parts and to perform the necessary checks. Having the VRO not working means the engine gets no oil so a mistake in the reactivation process can cost you an engine. Early VROs could be problematic. If it were mine, I'd continue to premix.
