Greetings and thanks in advance...I cant figure this out.<br /><br />This Motor is nearly new and (only has about 10 hrs on it) and is mounted on a 15" Geehnoe. While was running a river last weekend I reduced throttle to idle from about 3/4 (still breaking it in, so using 25/1 fuel/oil and running easy) to cast into a nice looking snag and when I throttled up...well, it dident. The motor will start on the first pull and runs at idle, but when throttled up there is no real increace in RPM's. It seems like it wants to, but it just wount. At home I put it on the stand and with the cover off, I can manualy advance the throttle and she will throttle up fine, but not with the twist grip. I have looked at everything I can think of, and all the linkage looks fine. Could I have a vacume leak?
