My 1996 50hp Johnson is losing power at full throttle. It cranks great and idles great. Sometimes it takes off and runs full throttle, but then dies down to about half or one-third throttle at times. When it is doing this, you can choke it and it takes off for a burst, but then dies down again. While acting up, sometimes if you pull back on the throttle it will pickup speed, but then die back again. <br /><br />I have checked the fuel filter. <br /><br />It has a new external tank, and new gas.<br /><br />Also, tried fuel tuneup through the carb/choke port.<br /><br />Any chance it is the fuel hookup to the tank?<br /><br />Pump up ball never really gets hard either?<br /><br />Thanks, Clark
