Re: what does running lean mean
When a motor is running lean, it means that the fuel to air ratio is wrong. A lean mixture has less fuel and too much air in the mixture.Motors that have two mixture needle valves, one for idle mixture and another for high speed operation , need to be adjusted seperately. A lean running motor will run hotter and can cause piston damage among other bad stuff. When the mixtures are set to too rich, the motor will run sluggish and foul the plugs.
