Rabbitdawghunter
- Jun 20, 2003
- 147
I'm working on a Johnson 115 HP 2000 year model.<br />Model # J115PLSSB<br /><br />The complaint was hard to start. Spark and compression test were good. Appears to be mostly oil coming from carb throats. This engine has the platic carbs and the optical ignition.<br />What should I suspect VRO failure or carbs need cleaning.
