115 Rude, water pressure
walleyehed
What would be a round about figure for an X-flow 115 @ 2000 or so RPM as far as water pressure???<br />Even high-Idle would give me an Idea.<br />Thanks!
rodbolt
Re: 115 Rude, water pressure
my 98 115 special idles about 5 psi and runs around 15 psi. new everything from pistons and bearings to lower unit gears.<br /> got the kit in to add OMS last week so I am waiting on some decent weather. then the rig goes on the market :)
walleyehed
OK, it's running about 5lbs at 1000rpm, so I should be ok...wanted to make sure the gauge was right too.
Solittle
5-10 at idle in the water and close to 20 on plane - 1987 1.6 L X-flow.
walleyehed
Thanks, SoLittle, that tells me I should be in the ball-park.
