Re: 67 18hp prop shaft questions
define worn out, my propshaft (40hp selectric shift) was worn around the rear shaft seal. I had local machine shop grind a few thou off it, and fitted speedy sleeve. works great, and is easily repaired in future if the sleeve wears out. cost 40 bucks for machineing and 25 for the sleeve from CBC. replacement shaft was US$120.00 for second hand, or US$240 for new shaft made to original specs. I feel for you, we don't have the same options here in Australia that the Americans do. If you do try to fit a speedy sleeve, you will need to find a machine shop that does centerless grinding. If they try and turn it down on a lathe they will really ruin it.
