Re: 1976 25hp Evinrude... Tell tale?
The 1976 was first year with tekktake, as far as I remember. Are U sure of the year. If U are, look under the lower cowling on starboard side. You will see a black nozzle, try to run a wire or something up it to clean what is blocking. Otherwose you may have a weak water pump.
