  #1
Old May 24th, 2005, 02:27 PM
reddog349 reddog349 is offline
Default 1977 evinrude 70 hp questions from new boat owner
First let me state I know little about motors so please excuse the simple questions. I just purchased a nice 1974 starcraft (exellent condition) with a 1977 70 hp evinrude outboard and notice the motor doesnot have the small jet of water coming out of the motor like my smaller evinrude. I decided to look into the motor and found that there was no hose connected to the hole where I assumed the jet of water would come out. Is this normal not to have ? I have started and run the motor several times(20 minutes each time) and it ran great and actually started better then my other outboard.Please let me know how to check the water pump - remeber Im all thumbs with this stuff.Any info would helpfull.
  #2
Old May 24th, 2005, 02:30 PM
Default Re: 1977 evinrude 70 hp questions from new boat owner
I also found a strange thing bolted to the motor next to the center spark plug with a wire going to the front of the boat but no connection.It seems to be actually held against the motor by a small bracket.
  #3
Old May 24th, 2005, 02:31 PM
Cricket Too Cricket Too is offline
Welcome to iboats. Are you saying the hose is just missing or there is no nozzle on the pan for a telltale?
  #4
Old May 24th, 2005, 02:32 PM
telltale?????????remeber im all thumbs.theres a hole but no hose and nothing comming off the motor like my smaller evinrude.
  #5
Old May 24th, 2005, 07:52 PM
Marauderk Marauderk is offline
My 77 70 hp evinrude has a pee hose on it
  #6
Old May 24th, 2005, 08:18 PM
mikeyzx2 mikeyzx2 is offline
my 77 V4 Evinrude has no "pisser" as you'll hear mentioned in other topics. Does your exhaust housing between motor and lower unit have two small round holes in the rear? they are relief ports and water spray will come out of them if yours has them. I have a picture of a 3-cylinder in my book and there's some sort of a connector right above the spark plug. it's a wiring harness of some sort that I see. There also a temp sensor wire running through there also, is the wire tan?There's also what looks like a water return hose running down the side of head in the picture, affixed with clamps. Hope some of this helps
  #7
Old May 24th, 2005, 08:28 PM
JB's Avatar
JB JB is offline
Folks who are "all thumbs" need a Service Manual even worse than some of the know-it-alls, Reddog.
__________________
RED SKY at night. . .
JB
  #8
Old May 25th, 2005, 12:01 PM
Mike, the wire is white although im sure it has been replaced because the motor was suppose to have been rebuilt a few years back.I hear from another person it may be a temp. sensor on the back of the motor , it has 1 white wire .I also noticed a red and a white wire coming out of the controls that has been cut off. The motor does have 2 small holes that do spray some .JB - I guess ill try ebay for that manual - Ive only had the boat a few days so I havent had time to get one.
  #9
Old May 25th, 2005, 12:02 PM
Is there anyway to make sure the water pump is working so the motor wont overheat????????????
  #10
Old May 25th, 2005, 01:05 PM
Ive run the motor several time for 20 minutes each time and I did put my hand on the side of the motor and it did get hot to touch(not burning hot) when it first started running but then went to a warm to mild temp.
  #11
Old May 25th, 2005, 01:49 PM
I guess I should ask this question - Is there a way to be sure the water pump is working correctly before I take it out ?\Id hate to burn up my motor.I plan on getting it checked by a repairman however theres a long wait with the warmer weather.
  #12
Old May 25th, 2005, 02:01 PM
dajohnson53 dajohnson53 is offline
Quote:
Originally posted by JB: Folks who are "all thumbs" need a Service Manual even worse than some of the know-it-alls, Reddog.
And also need a basic Owner's Manual which are usually available from the same sources that sell factory service manuals.For OP: check the mastertechmarine.com site for original owner's manuals. I've bought one for each of my old engines (a 82 Johnny and 74 merc) and find them very valuable for basic owner-non mechanic use. The factory service manual is handy if you want to actually repair things. The generic (e.g. Seloc) service manuals, I've found, are a little better for lay-person trouble shooting, but not as valuable as factory manual for the actual fixing.
  #13
Old May 25th, 2005, 02:25 PM
reddog, from the wiring diagram I'm looking at the red wire that I found runs from the rectifier to the terminal block found on motor, and from there to the starter solenoid. The white wire that I found is part of the neutral start switch, in which if that's the case be careful and make double sure that you don't have the motor in gear when starting or tinkering. There is a purple and red wire also from the ignition switch....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Some questions from a newbie boat motor owner (Johnson 70 VRO) sssports Johnson & Evinrude Outboards 11 January 10th, 2007 05:39 PM
New boat owner, have many questions. Cruzomatic Boat Topics and Questions (not engine topics) 7 September 12th, 2005 05:08 PM
HELP - new boat owner - Evinrude 85 hp 1973 bazeven Johnson & Evinrude Outboards 3 August 17th, 2005 07:25 PM
1977 Evinrude 35 HP questions BoatBuoy Johnson & Evinrude Outboards 1 June 2nd, 2005 07:41 PM
First Time Boat Owner - Questions Nacman Mercury & Mariner Outboards 7 July 26th, 2002 06:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
