As I was putting my motor back together, the manual called for OMC adhesive M for the bypass cover. I used the gasket sealer/maker on it. Now I am a bit concerned after reading another post where it sounded like adhesive M is the ONLY thing to use in specified applications. Other than that..I had the intake/reedplate gaskets on the wromg sides of the reedplate so I took it apart, changed them around and re torqued the intake back on..any foreseeable problems? Thanks.
