Re: Power head removal!
OK DoferGofer...(I was to when I was playing)...Here's what to do. You'll need some way to lift the heads, shop hoist, come-a-longs and a way to grap the head to lift....preferably one that will lift the head by the crankshaft.<br /><br />Once you got that, diconnect the fuel lines inside the pan, diconnect the battery cable, engine harness and TNT leads. Disconnect the control cables. Make sure the pee hole hose is disconnected also.<br /><br />Remove the two small covers below the lower engine pan. There are two screws in front, two screws inside the engine pan and two holding the front cover on you get to once the wrap around cover off.<br /><br />There's a nut and a bolt toward the front of the block under the lower engine pan, two studs with nuts at the rear of the engine block....a slim 1/2" wrench works well here...and three long bolts bolts on each side under the pan to remove.<br /><br />Inside the pan, look for two bolts holding the pan to the block, these will be toward the front of the block. Remove them.<br /><br />Disconnect the shift rod.<br /><br />Hook up the hoist and lift away. If the block sticks, shake it. It'll come lose.<br /><br />For a more detailed explanation with pics, get a OEM service manual.
