mstone1968
- Mar 1, 2005
- 60
Hello, I recently bought a boat with a 1953 Johnson RD-14 Motor attached. The motor actually appears to be in really good condition by just looking at it and the guy I bought it from said it runs great. I took it to the lake this weekend and it took about 20 minutes of pulling and choking to finally get it started. I had to leave the choke pulled out for a while in order for it to continue running. Otherwise it would shut off. I pushed the choke half way in and put it in forward. When I put it in forward and started down the lake, it really missed and bogged down a lot. It wouldn't run at all on a slow speed, I had to give it a lot of gas in order to keep it running. It is a 25 HP motor and definitely didn't get that much power from the motor. I am going to put some new spark plugs in it and hope that helps?? Does anyone have any tune up suggestions or know any information about this Old motor. Does anyone know the appropriate gas/oil mixture. The guy I bought it from said he used a 50:1 ratio. He said he preferred to run it on the rich side. I would just like to know for sure what it is supposed to be. Like I said, It literally took 20 minutes of constantly pulling the start cord to finally get it to fire, then it didn't run very smoothly after that. Any help or suggestions would be much appreciated. This is the first boat and motor I have ever owned. I know very little about outboard motors/small engines. Would anyone know of where to purchase a user's manual for such an old motor. Thanks for your help,<br />Mike
