  #1
Old May 22nd, 2005, 07:03 PM
Ficht Guy Ficht Guy is offline
Default 2000 Evinrude Ficht Stalls While Trolling
Gotta a question for ya. Today I was out on the lake and after about 15 mins of trolling in a slow-no-wake zone my engine started to sputter and die like it was being starved of fuel. Primer bulb was firm, but pumped it anyways and after 2-3 minutes the engine fired back up only after I had the throttle all the way up. I throttled down and the engine continued to run very smooth and was fine for the rest of the trip. This also happened to me that last few times I took it out last year, just thought I had some bad fuel, but this fuel is fresh. Any ideas what might be the issue? All the times it has happened I have always been able to get her started again, but I don't want to take anymore chances. I also don't think it's a good idea to starve the engine of fuel for the sake of the injectors and for any other reason. I did not have any check engine or warning lights come on during the stalling. Thanks for your help!
  #2
Old May 22nd, 2005, 07:36 PM
REELSPORT REELSPORT is offline
Default Re: 2000 Evinrude Ficht Stalls While Trolling
might be the injectors might be a little dirty.There is a product on the market called seafoam you might want to get a can of this and add to your gas tank. Just follow directions on can and it will clean the injectors and even if that is not the problem it will do you motor good. good luck
  #3
Old May 22nd, 2005, 08:39 PM
Actually when i put in the fresh fuel in a few days ago I added some bombardier fuel system cleaner....The engine runs very smooth at all rpms with no hesitation...just has this issue of stalling, now that I think about it the engine did stall at the end of last year when I was going w.o.t as well when I was trolling for no apparent reason.
  #4
Old May 23rd, 2005, 03:08 PM
I just called the dealer and they said they are two weeks out...fun fun. Do you think it will hurt the engine to run it this upcoming weekend? I was hoping to get some boating in during the nice long holiday weekend.
  #5
Old May 24th, 2005, 02:47 PM
Cricket Too Cricket Too is offline
Ficht's eat up spark plugs, have you changed them, my 150 Ficht will idle like crap on old plugs, anything over 50 hours. FYI you don't really need a primer bulb on a DI motor, it's kind of like pumping the gas on a fuel injected car, pointless, mine didn't even come with one, I would take it out of the fuel line if I were you, if it starts to go bad, and they do, it could be affecting the pressure in the fuel system, which is integral to engine performance with Direct Injection. The bulb is only used on carbs to fill up the bowl before starting, the lift pump on a DI will keep a constant pressure in the system.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 Evinrude 225 Ficht kelly holmes Johnson & Evinrude Outboards 3 May 23rd, 2006 07:33 PM
2000 175 Evinrude FICHT MokieB Johnson & Evinrude Outboards 2 November 6th, 2005 07:24 AM
2000 Evinrude 175 ficht boatfever Johnson & Evinrude Outboards 3 August 2nd, 2005 10:30 AM
2000 150 Evinrude FICHT Hemlock Johnson & Evinrude Outboards 1 September 25th, 2003 09:12 AM
2000 evinrude ficht ram peanut22 Johnson & Evinrude Outboards 2 May 19th, 2003 07:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
